Hi Chaps,
Can anyone recommend a replacement pulley for my ND altenator to run on my pinto? The altenator came with a flat belt pulley, and I need a V pulley
for the crankshaft/water pump belt. I got one from cambridge motorsport but the V is narrower and wears down the belt.
James
I've got one that came off my Denso alternator as I had the opposite problem to you.
Not sure if it is any different to the one you have, but you are welcome to have it if you want.
Stu
Do you have a picture of it by any chance?
James
