heyzee
posted on 24/1/04 at 08:22 PM |
mk indy
i might be thinking of buying a mk indy and have a few questions 1 do you use the stearing colum steering rack and hubs for the sierra?or do u use
escort rack and cortina uprights?2 is it easy to fit a z-tec or vauxhall 16v motor,3 do you need to get the rear driveshafts shortened??or do the
standard ones fit.last of all are these kits good value for money
Mk-Ninja
posted on 24/1/04 at 08:31 PM |
The Indy is based on the sierra.
1. Yes Sierra stearing colmn.
2. Dont know, but someone will know or ring Martin at MK.
3. Rear drive shafts are standard sierra, either disc braked or drums.
Last of all. I got my kit in November, I am really pleased with it, the quality is first class, support from MK is excellent, everything has fitted,
cant ask for much more. I would definetly recommend it.
I would suggest that you had a day out and went to the MK factory you wont be disapointed.
Gordon
I'm sure I've got one, just don't know where I've put it
jacko
posted on 24/1/04 at 08:33 PM |
Heyzee
1 yes sierra
2ztec yes dont know about v halls
3no standard length
4very good value
jacko
chrisg
posted on 24/1/04 at 08:35 PM |
1. steering column, modified Sierra, front hubs Sierra( with "mushroom"insert)
2. Cars have been built with both engines and the new MK demonstrator is to have a Zetec.
3. The Indy uses standard Sierra drive shafts.
Good Value?
Compare the prices, go and get a test drive at a few of the manufacturers, make your choice.
HTH
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the
error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Mk-Ninja
Bit late there Chris
chrisg
posted on 24/1/04 at 08:36 PM |
again
heyzee
posted on 24/1/04 at 08:38 PM |
shockers
just one more what shockers fit is it the 12" between bolt hole ones or are they different.i have a set of new zeemering shocks the old type i
just wondered if they will fit or ill flog them
Mk-Ninja
posted on 24/1/04 at 08:43 PM |
Sorry dont know off the top of my head, if nobody post it before tomorrow Ill measure them and let you know.
Gordon
Mk-Ninja
posted on 25/1/04 at 05:04 PM |
Shocks. 330mm between bolt centres. Both front & rear, different spring rates front and rear
HTH Gordon
