Jasongray5
| posted on 14/1/09 at 03:59 AM |
zx9r diff?
The zx9r engine is quite apealing to me, as I have always liked kwaks.
But i'm not 100% sure which diff I would need. I have a 3.6 from my sierra.
Also, where can I find "malcs" stock list?
Many Thanks Jas Gray
How hard can it be?
http://www.flickr.com/photos/33261515@N03/sets/72157611049241239/
eznfrank
| posted on 14/1/09 at 07:18 AM |
His user name is yorkshire-engines so could just do a search for that.
Click HERE for his most recent stock list posting on here.
MK9R
| posted on 14/1/09 at 07:31 AM |
I have a zx9r but have a 3.38 diff, and i definetly would want it any higher, ideally i would like a 3.14 sierra or a 3.22 freelander. You can offset
it by running larger wheels.
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
mackei23b
| posted on 14/1/09 at 08:20 AM |
Running a 3.62 diff on with 15" wheels on mine
MK9R
| posted on 14/1/09 at 08:23 AM |
just to add i run 185/60/13's
Cheers Austen
RGB car number 9
www.trackace.co.uk
idl1975
| posted on 14/1/09 at 08:30 AM |
I have the same setup with a 'blade engine - nothing wrong with a 3.62 with ZX-9R power and torque output.
rj
| posted on 14/1/09 at 12:22 PM |
3.62 diff and 195/50/16 tyres on mine, 123mph @12000 in 6th
Jasongray5
| posted on 14/1/09 at 12:44 PM |
Cheers for all the advice guys, Im not decided on my engine just yet, but all advice like this is helping me make up my mind!
How hard can it be?
mistergrumpy
| posted on 14/1/09 at 04:41 PM |
I'm trying to run a 3.62 with mine but the sodding thing is playing up.
Can I just comment on the ZX9. I have worked on a Fireblade and it was loads easier to wire up and also seemed a little bit shorter. With the ZX9
you'll struggle to keep it all under the bonnet and have the bottom sticking out. I've had to use tall bodywork.
Also the gearboxes have the reputation of being weak. Given the choice again I'd use a Fireblade.
Guinness
| posted on 14/1/09 at 06:20 PM |
Have a look for gearcalc which is a spreadsheet that Chris Gamlin has on the bottom of his signature. (Have a look for his posts).
That allows you to chose all the variables, engine, rev limit, diff ratio and wheel / tyre size. This then gives you a top speed in each gear.
HTH
Mike
