spdpug98
posted on 1/2/09 at 08:32 PM |
Engine Install - Bulkhead
I have dropped my engine in today and seem to of come across a problem, the gearbox casing is touching the NS bulkhead.
I can just about get a piece of paper between the bulkhead and the engine, is this a problem anyone has come across before
The engine is a 2003 R1
My Blog: http://spdpug98.wordpress.com/
jacko
posted on 1/2/09 at 09:14 PM |
Is the engine solid mounted?if so you should be ok but if it was me [ if you can ] put a indentation in the bulkhead to stop it vibrating on the
engine
Or ring mnr to make sure the engine cradle is made right
sucksqueezebangblow
posted on 2/2/09 at 09:34 AM |
I had the same problem, only about a 10th of a mm clearance. Checked with Marc he confirmed it was okay (engine is solid mointed, no rubber mounts
like a CEC).
spdpug98
posted on 2/2/09 at 09:57 AM |
Thanks, they all seem to be very similar but with varying (small) gaps - if that makes sense
Krismc
posted on 2/2/09 at 09:51 PM |
No rubber mounts on my zetec either. clearances tight and no knocks.
