Pdlewis
| posted on 9/3/09 at 02:02 PM |
setting up running gear
After driving my machine at the weekend (big smile still attached to face) I now know i need to do somthing about the setup of the wheels.
Does anyone have a numpty guide and what tools do i need/where do i get them from Im assuming i need somthing for angle of the wheels not sure about
this toe in toe out business
Build Photo Album
Updated 05/02/2009
Dangle_kt
| posted on 9/3/09 at 02:15 PM |
I know it isn't locost, but you could take it somewhere good to do it for you.
I plan to get mine looked at by someone, only because I think there is no point having £x thousand pound toy that doesn;t handle very well. Thats the
whole point of it to me.
I know it can be self done, but I'm not sure how good of a job a complete novice can do. (based on your "not sure about this toe in toe
out business"
Pdlewis
| posted on 9/3/09 at 02:20 PM |
I was going to do this post SVA as it was my understanding the SVA needs a slightly different setup which is not optimal for these kits
Build Photo Album
Updated 05/02/2009
| posted on 9/3/09 at 02:23 PM |
Only if you need to fudge the setup to improve flaws introduced by incorrect geometry in the first place e.g. self centering.
edspurrier
| posted on 9/3/09 at 02:27 PM |
I think worth getting camber, tracking and so on done properly. You can only do these things at home properly if you have some of the right tools and
a perfectly level floor to work off. You can I think get it just about OK with a spirit level and basic tools, but if your floor isn;t level and you
don;t have the right bits it will never be exactly right.
Pdlewis
| posted on 9/3/09 at 02:51 PM |
Ok my only problem is getting the car places until it is registered as I missed been able to tow a tralor by a year so dont really have a legal way of
moving it. I managed to get my bro to take a day off for the test to pull it up there but otherwise im a bit stuck this is why I was going to do it
my self for the SVA then get set up by someone after
Build Photo Album
Updated 05/02/2009
Danozeman
| posted on 9/3/09 at 03:58 PM |
How heavy is your car? If you get hold of a lightweight trailer you should be just in the limit to tow it?
Dan
Dangle_kt
| posted on 9/3/09 at 04:29 PM |
lewis, when did you pass your test? What car do you have?
Im pretty sure you'll be fine with the right trailer.
I use my lightweight trailer, complete with locost car perfetly legally.
Pdlewis
| posted on 9/3/09 at 04:51 PM |
I passed my test in 2000 I have looed into towing before but the trailers i have access to are all ifor williams which means i can tow them empty but
as soon as you put a spade on the back it is over weight from my leicence
Build Photo Album
Updated 05/02/2009
RichardK
| posted on 9/3/09 at 04:59 PM |
I did mine like this
LINKY
and seems near enough as a starter position.
Rich
Gallery updated 11/01/2011
