soutinho
| posted on 10/3/09 at 12:35 PM |
Yamaha R1 engine 2002-2003
Hello!
I'm finishing the assembly of my car and i would like to try it on track, next Sunday
The engine is the r1 2003. I haven't installed any "power commander" or "rapid bike" yet..
I would like to know the limitations i will have with the engine running on stock maps (like rpm, oil pressure and temp., water temp.) and which
advices can you give me for 1st time use on track.
here is the car:
http://www.youtube.com/watch?v=See9whfGTzU
http://www.youtube.com/watch?v=4bNK5mfuDI0
Thank you for everything.
Cheers from Portugal,
soutinho.
Paul TigerB6
| posted on 10/3/09 at 12:42 PM |
I would be very wary of running the car without a power commander on track as the engine will probably be running quite lean (which can ultimately
lead to melted pistons etc in the worst case). Can you not get one in time and run it with a borrowed map??
| posted on 10/3/09 at 12:47 PM |
Without looking at the vids on Youtube, are you running the engine with the stock airbox and exhaust can?
Phil
ko_racer
| posted on 10/3/09 at 01:24 PM |
There is no change to the oil, rpm or temp using a powercommander. It only affects the fueling (unless you have an ignition module)
I would not risk using the stock map on track especially if the air temps are warm.
You could however richen up the mid to top by 5% on the powercommander and I'd say you'd be fairly safe, though wouldn't want to
garauntee it.. You really need to get it checked on a RR.
It is very easy to melt pistons & blocks on these engine.
I'd also suggest if the engine uses 9 plugs as standard to use 10's instead.
I've a stack (albeit from an 04-06 motor) of barrels and pistons in my garden with holes and scores from last years racing.
progers
| posted on 10/3/09 at 01:46 PM |
The 2002/3 motor is far more robust than the later 2004 + motor - it is nowhere near as marginal on cooling for example. So take the above comments
with a pinch of salt.
Ideally you should use a PC but as long as you are using the airbox and you are not ragging it at 11K+ rpm all the time you should be OK. Keep an eye
on temps and come in if you see water and/or oil temps that are too high.
Once you get a PC there are several maps from dynojet that will be close to what you have. Alternatively richening up the top end a bit should keep
you safe. CR9e Iridium plugs work well.
- Paul
soutinho
| posted on 10/3/09 at 04:24 PM |
Thank you very much for all your replies.
I've just ordered one PC, which will arrive on Thursday, by the afternoon
Thanks again!!!
Bye,
Luis.
soutinho
| posted on 13/3/09 at 10:03 PM |
Hello!
Situation is solved.
PC installed
Images:
PC INstalled
The Car - MNR Vortx Rt+
easisatman
| posted on 14/3/09 at 06:34 PM |
registered
Hi Soutinho
Car looks great have you managed to get it registered for the road? or is it just for track days? I am just trying to get a uk registered Striker with
a R1 engine registered here in spain.
