Author: Subject: Steering coupling(I think) siezed
Staple balls
posted on 16/5/09 at 02:40 PM Reply With Quote
That thing, there, it's stuck, any ideas how to get it off non destructively? otherwise, destructively and where do I get a new one?
adithorp
posted on 16/5/09 at 02:58 PM Reply With Quote
I presume you mean siezed on the splines.
Drive a small chisle or screwdriver into the slot. Should come off easy enough then.
adrian
http://jpsc.org.uk/forum/
Staple balls
posted on 16/5/09 at 03:02 PM Reply With Quote
tried that with a screwdriver, will try a chisel later when it's less wet out there.
theconrodkid
posted on 16/5/09 at 03:03 PM Reply With Quote
nice and sunny here
who cares who wins
pass the pork pies
handyandy
i,ve got a spare if you bugger yours up getting it off.
andy
mr henderson
posted on 16/5/09 at 03:07 PM Reply With Quote
Originally posted by theconrodkid
nice and sunny here
Not raining here, and I'm closer to him than you are
Staple balls
posted on 16/5/09 at 03:14 PM Reply With Quote
Nice and sunny now, but the drive's still a bit nasty.
Ended up working through an hour long horizontal shower earlier, not pleasant.
tomgregory2000
posted on 16/5/09 at 03:37 PM Reply With Quote
I dont want to hijack but is there a replacement upgrade for that part that doesnt involve a huge bit of soft rubber, so the feel will be a bit sharper?
chris_harris_
posted on 16/5/09 at 03:43 PM Reply With Quote
I ground of the heads of the studs, removed the rubber then bolted it together instead, took all of thirty minutes, and much beter IMO.
Regards Chris
Staple balls
posted on 16/5/09 at 03:49 PM Reply With Quote
Got it.
I was using the wrong random implement found in the shed, the right one did the job nicely.
Oh, and it started raining again as soon as I got outside.
mr henderson
posted on 16/5/09 at 04:16 PM Reply With Quote
Still OK here
Staple balls
posted on 16/5/09 at 04:24 PM Reply With Quote
Still OK here
I hate you.
posted on 16/5/09 at 04:44 PM Reply With Quote
Have a look at Rally Design, they do a U/J coupling IIRC.
James
posted on 16/5/09 at 05:36 PM Reply With Quote
Luego do a polyurethane one IIRC.
Or they did about 4/5 years ago!
HTH,
James
posted on 16/5/09 at 06:24 PM Reply With Quote
Still OK here
Been nice here all day.
