Author: Subject: BEC Emissions at MOT time
Wheels244
posted on 22/5/09 at 07:15 PM Reply With Quote
I know it's 3 years off for me yet.
But,
I assume there will be a lot of builders in the same boat as me, in that they struggled like hell to get their BEC's through the SVA emissions including fitting Cats, leaning them right out etc to pass the emissions test.
Now I assume a lot of Cats have been removed and mixtures correctly set - so what is everyone going to do come MOT time ?
Guinness
posted on 22/5/09 at 07:16 PM Reply With Quote
I take mine to the right garage
Mike
COREdevelopments
posted on 22/5/09 at 07:22 PM Reply With Quote
Get friendly with an MOT tester.
Rob
smart51
posted on 22/5/09 at 07:24 PM Reply With Quote
Mine is on a Q plate so visible smoke for me last December. Some tell me that a Q plate is harder to sell on but I bet it isn't when you explain the benefits.
I've heard it said that all kit cars are exempt bit I'm not so sure. In any case, you made it pass once, you can do it again surely. It only has to be "right" at 2500 RPM.
Howlor
posted on 22/5/09 at 07:34 PM Reply With Quote
I presume everyone else is the same however with the DVLA that is probably not the case, my V5 had the emissions detailed on the bottom that it had to pass so I presumed they would have then used these at the MOT.
smart51
posted on 22/5/09 at 08:00 PM Reply With Quote
So does mine so I forgot to take it to the MOT. They typed in the car info by hand and did a visible smoke test. I now have a visible smoke MOT certificate to take with me to the next test.
Howlor
posted on 22/5/09 at 08:01 PM Reply With Quote
Crafty!
nitram38
posted on 22/5/09 at 08:33 PM Reply With Quote
It's called a POWER COMMANDER!
Just going to sling the map that passed sva back in!
Wheels244
posted on 22/5/09 at 08:38 PM Reply With Quote
Yes, I could do that with mine - but what about refitting the Cat - I borrowed MNR's so it's not on my car now.
nitram38
posted on 22/5/09 at 08:55 PM Reply With Quote
I'm leaving my CAT on..........
