craig_thomas
posted on 11/9/09 at 07:28 PM |
brakes
i have 2 master cylinders fitted to my locost and intend to have a dual circuit system with balance bar fed by 1 resevoir. running sierra brakes all
round. will this pass IVA.
nib1980
posted on 11/9/09 at 07:31 PM |
so long as you have a fluid level sensor i don't see a problem.
oh and the balance bar will need to be locked off
prawnabie
posted on 12/9/09 at 08:49 AM |
Check the regs as the IVA has changed IIRC to say that if one circuit fails you need to still have a certain %age of force on the other circuit. This
is a problem with 7's if the fronts fail as they hardly have any braking on the rear circuit.
May be way off the mark of course but I'd just check to be certain!
