johhny5
| posted on 27/12/09 at 10:04 AM |
water temp sensor question
Hi, I have a pinto engine in my car.
Can i use the temp sender mounted in the engine block to see what the water temp is.
I am using a standard smiths type gauge.
Tried to wire it up but does not seem to show the corect temp.
Could somebody give some ideas so i can check the wiring,
cheers
John
By the way just used my chrimbo present a dremmel to cut sausage filter hole it bonnet, just the job ,well done santa !!!
turbodisplay
| posted on 27/12/09 at 10:29 AM |
All temp sensors have different characteristic resistance/temperature relationship. You need a compatible gauge and temp sensor.
Darren
gregs
| posted on 27/12/09 at 05:13 PM |
one of these should have you sorted
linky
