Author: Subject: weber alpha for duratec no sparks
speedystew
posted on 25/4/10 at 09:00 PM Reply With Quote
as it says on tin...weber alpha pro 4 throttle body kit on 2L duratec engine
finally got the car to run on saturday morning for a few min's then turned it off to put put a few bits back on the engine (nothing that's disturbed any wiring)
Now the problems,cant get the dam thing to spark now,coil packs getting about 10.5 volts when engine is cranking but no spark
tried it on three battery's,1 that runs a motorhome and still can't get more than 10.5 volts to coil when cranking
any ideas ?
matt_gsxr
posted on 25/4/10 at 09:20 PM Reply With Quote
My cranking voltage is lower than 10.5v and sparks are fine. Obviously its a different set-up (megasquirt in my case on a bike engine).
Is your trigger wheel doing the right sort of things?
speedystew
posted on 25/4/10 at 09:39 PM Reply With Quote
i'll check the cps sensor matt
cheers
perksy
posted on 25/4/10 at 09:45 PM Reply With Quote
Stew
are you getting fuel ok ?
Crank sensor definatly worth checking *if* you aren't
Double check all the connections and the Plug at the ECU end
iirc the ECU will need a minimum of 10 volts otherwise it will sulk and start playing up
Webcon Alpha unit should just 'plug & play' but as you know not being able to connect a laptop and see what its doing can be a pain in the ass when it come to diagnosis
[Edited on 25/4/10 by perksy]
speedystew
posted on 25/4/10 at 09:56 PM Reply With Quote
a-up perksy
yeh its getting fuel, just lost sparks....it may wind up going to troys to sort it out but don't fancy a trip to northamton to find out it's a duff battery or coil pack
will you lot be at stoneleigh for a few beers this weekend ?
perksy
posted on 25/4/10 at 10:07 PM Reply With Quote
have Seen Coils be ok with a Multimeter but fail under load Mate
Trying a Spare one would sort that idea out (You've already checked for voltage at Coil end)
Worth having a chat with Troy if you don't get any luck with Webcon
He's a Top bloke and very helpful
No Stoneleigh this year i'm afraid Mate
Really busy at work at the moment and have also been spending more time working on mates Westy's/Cars and not enough time working on mine
Hope you have a good one if your going Mate
speedystew
posted on 26/4/10 at 09:13 PM Reply With Quote
all sorted the only thing i did not check was the relay's turns out 1 was not switching
all running......happy chap
