Wibber
posted on 12/5/04 at 12:24 PM |
Trailing link mounting hole dia
In the book it shows the holes for the bolt that will go through bushes on the axle bracket for the rear supension to be 11/16 inches dia. Why?
Isn't the bush internal dia 3/8"? Shouldn't the holes be the same diameter? Am I missing something?
James
posted on 12/5/04 at 02:05 PM |
Bear in mind the book's full of errors so I suspect this is just another one.
Note that the rear axle bracket hole spacing is different too- the spacing needs to be the same or the axle won't lift or drop under bump!
HTH,
James
