jossey
posted on 8/6/10 at 08:56 AM |
L bracket supplier help???
i need alot of L brackets at the moment.
to mount the following on my car.
Nose cone.
Scuttle.
bike engine frame to chassis.
Brake line flexi pipe to copper pipe.
and various other bits.
is there a supplier of L brackets in Steel to i can weld them to my frame and save me making them.
Cheers in advance all.
[Edited on 8/6/10 by jossey]
posted on 8/6/10 at 09:09 AM |
Do they need to be that thick? B&Q have a lot of thinner but still structural brackets in the building and framing sections.
big-vee-twin
posted on 8/6/10 at 09:13 AM |
I use 20mm wide x 2mm thick aluminiun strip from B&Q they only cost a few quid for a metre
http://www.triangleltd.com
jossey
posted on 8/6/10 at 09:29 AM |
need thick ones for holding the engine frame on. and thick ones to hold radiator on. other ones not so thick will be fine.
also some half brackets would be good too. a little like below.
dave
tegwin
posted on 8/6/10 at 10:07 AM |
Buy a length of steel L section... get a decent jigsaw and blade and chop it into pieces... drill the holes and use a grinder to round the corners...
10 mins per bracket! Cost.... about £0.20p!
www.verticalhorizonsmedia.tv
James
posted on 8/6/10 at 10:20 AM |
For my nose cone and scuttle I just set riv-nuts into the top chassis rail.
James
- Muhammad Ali
eddie99
posted on 8/6/10 at 10:30 AM |
James
+1
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
jossey
posted on 8/6/10 at 10:48 AM |
Thanks everone. cheers.
will give it a go.
how do i use the riv nut things?
thanks all.
mangogrooveworkshop
posted on 8/6/10 at 11:03 AM |
will give it a go.
thanks all.
Go to MEMFAST and pay the money for the tool 36 bucks for the base and tenner for the mandrels.
I wish i had bought one ages ago.....best thing ever
jossey
posted on 8/6/10 at 11:19 AM |
thanks all. will have a go then....
A1
posted on 8/6/10 at 11:38 AM |
steer clear of the b&q stuff, it might be cheap but its complete crap. the aluminium is especially appalling.
stevegough
posted on 8/6/10 at 04:13 PM |
ally best (and cheapest) from scrap metal merchants
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
