jabbahutt
posted on 12/10/10 at 07:04 AM |
non mechanical securing of alumnium
Morning all
Time to pick the collective brains here again. I have a piece of 10mm ali tube which needs securing to a non circular ali bar.
I've filed the bar so that it's a reasonably snugg fit inside the tube, though there are gaps where there isn't metal to metal
contact. I wish to permantly attach the bar inside the tube and it will be taking a small amount of weight (50g)
What would you lot recomend for producing a decent bond? I was thinking either sikaflex or araldite.
Opinons please on those options or any other ideas. Solution must be readily avaialble without resorting to the interweb etc.
Many thanks
balidey
posted on 12/10/10 at 07:24 AM |
I would go with araldite, or any 2 part epoxy type adhesive. Just key and clean the faces well first
Dutch bears have terrible skin due to their clogged paws
tony-devon
posted on 12/10/10 at 07:32 AM |
as above, 2 part epoxy resin,
or JB weld
I use that to build up areas and then drill and tap it, really is very good.
fine with heat, fuel etc
heavy is good, heavy is reliable, and if it breaks, hit them with it
jabbahutt
posted on 12/10/10 at 07:36 AM |
Many thanks fellas, this site never lets me down.
RazMan
posted on 12/10/10 at 07:43 AM |
Have you considered alluminium solder?
Raz
CNHSS1
posted on 12/10/10 at 08:30 AM |
Lumiweld?
marcjagman
posted on 12/10/10 at 09:07 AM |
ALLY SOLDER? Never heard of it, where do you get it from, how do you use it etc?????
posted on 12/10/10 at 12:23 PM |
You don't say if the bar is round or square.
If round a pity you filed the bar otherwise you could have heat shrunk the tube on.
If round and close fit use superglue.
posted on 12/10/10 at 12:40 PM |
It's just a special alloy solder that will bond to aluminium. It's quite difficult stuff to use IME, you have to use special flux with
it. Quite a few places sell it - I even seen it at B&Q, and Maplin definately sell it.
CNHSS1
posted on 12/10/10 at 01:05 PM |
Lumiweld as my prev post
