angliamotorsport
posted on 3/7/11 at 06:16 AM |
injection pumps
Can anyone tell me which is better, intank standard bike pump or out of tank injection pump and adjustable regulator.
The application is for a hillclimb car.
Last time I used the standard intank pump but felt sometimes at the top end of the revs, particulrly in top gear, the engine was not quite
delivering.
Any thoughts.
matt_gsxr
posted on 3/7/11 at 08:58 AM |
I am a fan of the intank pumps.
The advantages (as I see them) are that this has been implemented, tested and proven by a series of large multinational companies. The solution is
neat and light
The only disadvantages are:
Filters are difficult to clean and check.
Flow rate is limited to the existing pump
You can't implement manifold referenced fuel pressure (so no good with Turbos)
If you could conveniently log the fuel pressure, then you could diagnose whether the in-tank pump is the problem. Fitting an external pump, FPR, new
fuel take-off and fuel return and filter is going to cost a fair few quid and be quite a lot of effort.
I have just swapped pumps (turbo install) and it was a shame to take out such a reliable sub-system.
Matt
posted on 3/7/11 at 02:01 PM |
neat and light
The pressure is controlled by the regulator, not the pump and the regulator is usualy reference to manifold pressure. Most if not all modern
turbocharged cars will use an in-tank pump.
matt_gsxr
posted on 13/7/11 at 09:08 PM |
neat and light
I am only familiar with motorcycle in-tank pumps (more specifically Suzuki ones). These have the regulator in the tank and are not manifold
referenced. Sorry for any confusion.
Matt
FatChapChipChop
posted on 24/9/11 at 03:06 PM |
Hi Matt;
I'm looking at what in-tank pumpto use to power bine bodies on a 1.8 Zetec .. Got any piccies of bike injection pumps, as I'm about to get
a tank made up, so would be good to know what I need?
Drive fast, don't look back!
