cs3tcr
posted on 26/6/12 at 04:29 PM |
Flywheel Bolt Circle Diameters
I'm hoping someone can help, i'm in the process of converting a Coventry Climax FWM to automotive use, and am trying to find a suitable
flywheel. I know i can have one custom made, but i'm trying to possibly find something that already exists. The Climax crank has a 6 bolt
pattern on a 2 3/8" PCD, the bolts are 5/16" UNF but the holes in the existing firepump flywheel measure 0.320" in diameter. Can
anyone help?
Thanks,
Rod
owelly
posted on 26/6/12 at 04:43 PM |
Hows about the Hillman Imp? Does it not share the same engine?
http://www.ppcmag.co.uk
cs3tcr
posted on 26/6/12 at 05:08 PM |
The engine is similar in construction and layout, but from what i've found so far, they share very little in terms of parts. I had a look
online in regards to the Imp flywheels and they appear to be a 4 bolt flywheel for the early ones, and a 5 bolt for the later ones.
Here's a pick of the FWM:
