Author: Subject: 6 point harness into 4 ?
welderman
posted on 31/5/13 at 07:53 AM Reply With Quote
How do fellow car builders, ive got some 6 point harnesses and only need 4 point, is it ok just to use 4 straps or are the fastenings on the buckle in a different place ?
Thank's, Joe
I don't stalk people
pekwah1
posted on 31/5/13 at 08:05 AM Reply With Quote
I've got 6 points but I just use four.
Should be as simple as unplugging the crotch straps and leaving them off!
macc man
posted on 31/5/13 at 08:19 AM Reply With Quote
It is better to use all 6 if fitted. This will prevent submarining in a crash. I modified a pair of seats by cutting a slot in the seat bolster and sandwiching a chrome bezel to a piece of plywood under the seat. It works well and is very neat.
blakep82
posted on 31/5/13 at 09:35 AM Reply With Quote
The prima motorsport titon ones ive got all have the same buckle.
I ordered 4 point, but asked if I could get the 6 point straps later, they said all harnesses use the same buckle, so yes, I'd say you can.
The only difference with primas ones is that in 6 point, the buckle is fixed to the lower straps, where in 4 point, the buckle is fixed to a side
________________________
welderman
posted on 31/5/13 at 10:15 AM Reply With Quote
ah ok then cheeeeerrrres fellas, I will use the 6 but as a 4 , and if I need to upgrade I will have spare straps, happy days
Thank's, Joe
RK
posted on 2/6/13 at 02:47 AM Reply With Quote
That's what I've done. It is expressly not allowed to run 6 point on the road here.
snakebelly
posted on 2/6/13 at 07:27 AM Reply With Quote
Just as an aside, why are you not allowed to run 6 point?
adithorp
posted on 2/6/13 at 07:40 AM Reply With Quote
Hi Joe, I've just acquired new Ricco 4-point harnesses. They have the 5th slot for 6-point crotch straps. The Ricco web-site confirms they are the same buckle and they sell the strap to upgrade to 6-point.
How's the rebuild coming along?
http://jpsc.org.uk/forum/
welderman
posted on 2/6/13 at 08:02 AM Reply With Quote
Builds coming on quickly at the moment. Had a good few hours on the car over the bank holiday weekend.
Had a problem with the clutch but sorted that on Friday.
Need to sort paddle shift out next.
Blead the brakes and I might be able to run and drive it in the yard
Then Finnish all the little bits that's needed to hold it together haha
Thank's, Joe
