dmottaway
posted on 10/3/03 at 04:02 PM |
chassis front width
when building a book chassis, can somebody tell me how far apart the suspension brackets are?
Not the width of the wish bones, but the distance between the centers of the bolt holes of the top brackets (left and right) and then the same
measurement for the bottoms. To clarify one step farther, if you put a rod through both top brackets on one side and another rod through both
brackets on the other side, how far apart would the two rods be?
And the two rods should be parallel to the center line of the chassis, shouldn't they?
thanx
dave
theconrodkid
posted on 10/3/03 at 05:22 PM |
tops should be 594mm,bots 418mm,distance between top n bot bracket is 204mm(acording to chairman ron)
who cares who wins
pass the pork pies
Hornet
posted on 11/3/03 at 08:08 AM |
I have done a small CAD of dimensions using the actual brackets i bought.
I cannot attach till l8r so have put it in my photo section for now.
They are different from the above dimensions however the bracket hole centres are 27mm from the base of the bracket.
Cheers.
dmottaway
posted on 11/3/03 at 03:16 PM |
thanks to both of yo! exactly what I was looking for.
dave
Hornet
posted on 11/3/03 at 07:37 PM |
Save ya a long trek lookin
