Danozeman
posted on 9/7/06 at 09:06 AM |
megajolt coil wiring.
I have megajolt running my zetec and a vicky green loom. Theres 2 white wires for the ign system. I have the whole lot wired from one of the wires
for the ign feed as shown on the wiring diagram. Is this ok for the coil though?? it runs well so theres not a problem just wondred if this thin
wire was ok for the coil, mj and edis together.
Dan
paulf
posted on 9/7/06 at 07:34 PM |
i dont know how thin the wire is ,but the current draw of the edis and megajolt is only a few milliamps, the only real load is the coil when
energised, I assume that if it is designed for a standard ignition system it will be fine with the megajolt.
Paul.
Danozeman
posted on 10/7/06 at 04:13 PM |
cheers Paul. i will leave it as it is for now then.
Dan
