lough
| posted on 8/11/06 at 10:13 PM |
Rear disc brakes
I’m looking at fitting disc brakes to a escort rear axel and have a new set of golf rear callipers left from a previous project , has anybody ever
fitted golf callipers before?
Fatgadget
| posted on 8/11/06 at 10:48 PM |
Id have thought the principle is exactly the same as fitting any other set of calipers/discs.
Years ago we used to fit Chrysler 180 discs and calipers to Escort and Sunbeam axles. All that was required was fabricating caliper mounting brackets
and arc welding them onto the axle.
Give Fostek.co.uk a shout I am sure they will sort you out with the necessary hardware you might require.
lough
| posted on 8/11/06 at 10:57 PM |
Thanks I have just had a look at their web site and I will give them a ring tomorrow.
gazza285
| posted on 9/11/06 at 04:00 AM |
If the calipers are the same as the Audi ones (Audi 100 I think), then I've got a set of bolt on brakets for an Escort axle. These fit using a
solid Fiesta/FWD Escort disc.
| posted on 9/11/06 at 07:48 AM |
Yep norm is to use Mk3 Escort solid front discs, (also fitted to some 1.3/1.6 Sierras) --- very cheap from most motor factors.
lough
| posted on 9/11/06 at 08:37 PM |
Will contact you via U2U
Kook
| posted on 23/11/06 at 06:14 PM |
Hi I have got Golf gti Brake Calipers also have got Mk3 Escort solid discs and am making the Bracket at the min ... Is 5mm thick steal thick enough ?
