New Topic New Reply
Author: Subject: Engine Bay Side Protection
mistergrumpy
posted on 23/11/06 at 08:54 PM Reply With Quote
Is there any reason why round tube instead of square is used up front to triangulate the engine bay sides?
tks
posted on 23/11/06 at 09:12 PM Reply With Quote
its stronger
round tube is even strong in every direction.
Square tube not.
you always want as much distance from the 0 line this is a virtual line in every profile...
Tks
mistergrumpy
posted on 23/11/06 at 09:15 PM Reply With Quote
I see. It encompasses a greater area thus making it stronger. Cheers.
adampage
posted on 24/11/06 at 07:50 AM Reply With Quote
I always thought....
That the triangulation on the side of the engine bay was in round tube so that the aluminium panel can bend around it smoothly.
The panel there isn't flat you see, the bottom front corner is some way inboard of the top and rear edges, therefore it needs to bend along the line of that diagonal tube.
If it was square it would have a sharp crease, round = smooth curve.
Well, that's what i thought anyway!
Adam
posted on 24/11/06 at 08:54 AM Reply With Quote
not quite, see what ^^^^ said re: "stronger in every direction"
You could take your round tube and squash it to make it oval, then it becomes stronger than round tube in one direction but weaker in the other.
New Topic New Reply
