Author: Subject: SVA Approved Mirrors?
Davey D
posted on 3/9/07 at 09:20 PM Reply With Quote
Im after some Carbon Fiber mirrors for my VortX kitcar once i start building. ive seen Caterham do the Centre Mirror, and wing mirrors in Carbon.
https://www.caterhamparts.co.uk/product_info.php?cPath=96&products_id=106
and
https://www.caterhamparts.co.uk/product_info.php?products_id=444
i presume that they should pass the SVA since they are supplied fitted to the CSR?
bigrich
posted on 3/9/07 at 09:30 PM Reply With Quote
i would doubt if they are compliant, don't appear to have radiused edges etc also look just like SPA or racetech mirrors.
I thought the CSR and similar were production cars and as such don't go through SVA or am i talking bull??
Rich
jambojeef
posted on 3/9/07 at 09:37 PM Reply With Quote
My centre racetech mirror failed SVA - radiuses were the prob - also it was *just* big enough reflective area wise - Id not realised that was a requirement but the SVA tester came out with a little paper template and laid it over the glass and it was about 1mm oversize all the way round!
I think the Caterhams get type approval where I guess they must submit a nicely radiuses rubber covered CSR to Mr SVA which they then sell on without and of the rubber bits.
At least I think thats what type approval is!
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 4/9/07 at 09:43 AM Reply With Quote
I used my racetech rear view mirror for sva with no mention of an issue on size. I radiused the edges with some big foam U-trim, cut in half and glued on to a strip of insulation tape around the edge of the mirror. This means no mess when removing, only a 10 minute job.
