2b_pablo
| posted on 8/10/07 at 09:44 AM |
Which pinto cam?
Currently running a Burton BLF40.41 rally cam which I think is a little lairy for the car.
So Im thinking of changing to a fast road type cam to make better power lower in the rev range and maybe work a bit better with the twin 40s.
Any recommendations?
2.1 pinto
ported head
leccy ignition
twin weber 40s
thanks
ash_hammond
| posted on 8/10/07 at 09:48 AM |
Piper 285 - not a lary cam, nice smooth power delivery.
- Ash
.: www.mac1motorsports.co.uk | www.m1moc.com :.
macspeedy
I was running fully balanced, flowed head 2 ltr with 45's with a kent fr32 cam kit, very torquey very driveable once we had the timing running
right, we had a homemade electronic brain for advance, I have the advance curve figures i can send you.
Mac
2b_pablo
| posted on 8/10/07 at 09:57 AM |
my ignition isnt adjustable tho, its the bestek system
mark chandler
| posted on 8/10/07 at 09:58 AM |
Before binning what you have got try advancing the cam a bit, around 7 degrees will pull in some mid range and bottom end power.
2b_pablo
| posted on 8/10/07 at 10:01 AM |
its around 11deg atm if that helps
2b_pablo
| posted on 8/10/07 at 10:04 AM |
40.41 cam is:
.450" LIFT/324deg DURATION:
mookaloid
| posted on 8/10/07 at 10:31 AM |
quote: Originally posted by 2b_pablo
40.41 cam is:
That cam does seem a rather wild for road use - that duration is for a full race cam. I would recommend some thing with a duration of 280 - 300deg.
Since you have a gas flowed head, I would go for nearer the 300deg as you will be wasting the abilities of the gas flowed head otherwise.
HTH
Mark
2b_pablo
| posted on 8/10/07 at 10:36 AM |
Burton do this one:
BURTON ROAD/RALLY CAMSHAFT .460" LIFT/300deg DURATION: SOHC PINTO
might calm things a bit. Its drives ok but Ive a feeling when the carbs are running out of puff the cam is just getting going at the minute.
mookaloid
| posted on 8/10/07 at 10:47 AM |
Burton do this one:
Sounds about right - You might want to check you have the maximum choke sizes you can get in your 40's i.e. 36mm
mark
[Edited on 8/10/07 by mookaloid]
2b_pablo
| posted on 8/10/07 at 10:49 AM |
cheers
would I need to get all the kit parts as well? The 40.41 wont have been in too long really so wont have suffered from much wear.
mookaloid
| posted on 8/10/07 at 10:51 AM |
cheers
Ideally you should use new followers at least....
mark
DarrenW
| posted on 8/10/07 at 12:54 PM |
ive got the Fr32 but suspect it may be a bit tame for you. Mookys went very well ideed with the FR33.
i think Alistair at AMAC Engineering has been getting a new batch of his special pinto cams in as well recently. No idea of the spec but he seems to
be able to exploit the best a Pinto can give with them.
