whitestu
| posted on 13/10/07 at 07:42 AM |
Phase 3 Focus Blacktop Zetec Sump & Starter
I've come across a problem with my CVH to Zetec conversion.
The CVH starter motor won't clear the 2 piece Focus sump without taking some of the flange off between the two parts of the sump.
Has anyone had this issue and found a solution?
I know I can swap the sump, but was hoping for to find a smaller [i.e. thinner] starter motor that will fit.
Stu
stevebubs
| posted on 13/10/07 at 08:26 AM |
I sued an Angle Grinder to grind off the excess on my mondeo sump..
nib1980
| posted on 13/10/07 at 08:51 AM |
wow you can sue and angle grinder into work, cool
whitestu
| posted on 13/10/07 at 10:04 AM |
Did that involve grinding the flange where the alloy and steel bits of the sump join?
I'm concerned that if I grind enough for the starter to fit, the sump will leak.
Stu
SeaBass
| posted on 13/10/07 at 04:18 PM |
Mine did involve taking some material off the join. The joint at that point is about 15mm wide so it shouldn't start leaking...
whitestu
| posted on 13/10/07 at 04:20 PM |
That's good to hear - it looks as though it might need 5-10mm off to allow it to fit.
Stu
whitestu
| posted on 14/10/07 at 11:03 AM |
It fits now, after a bit more grinding.
Hope it won't leak!
Stu
stevebubs
| posted on 14/10/07 at 11:12 AM |
Stu
Yep
