Author: Subject: nosecone mesh
oadamo
posted on 3/12/07 at 09:11 PM Reply With Quote
nosecone mesh
hi has anyone got the sizes of the mesh that you need. cuz iam having some smart panels cut for it but need the sizes.
adam
i no iam a bit ahead of myself as i havent even bought the nosecone yet. but a guy is cutting them for me for a small fee. so iam gonna get them done while the offers there
adam
chris taylor
posted on 3/12/07 at 09:52 PM Reply With Quote
Nosecone Mesh
Hi adam
all the nosecones are slightly different and hence are different sizes, it would be a gamble if you had it cut without first having the nosecone to measure,
regs,
Chris.
austin man
posted on 3/12/07 at 09:53 PM Reply With Quote
mesh
if you havent got the cone how do you know the size? each manufacturer will probably have a digfferent shape or size albeit slight
oadamo
posted on 3/12/07 at 09:56 PM Reply With Quote
bugger lol thanks chaps.
adam
oadamo
posted on 3/12/07 at 10:02 PM Reply With Quote
or anyone got a rough sizes i could get them cut big then cut the outter to size.
adam
posted on 4/12/07 at 08:51 AM Reply With Quote
I played around with a sheet of cardboard cut from packaging. Fiddled around until I got a decent fit, then measured it up to see what I needed.
I then used the pattern to mark out the mesh.
HTH
westcost1
posted on 4/12/07 at 11:48 AM Reply With Quote
i just cut it with some tin snips easy
pewe
posted on 4/12/07 at 03:36 PM Reply With Quote
Just been through the same exercise for the F27. That required a piece 500 x 300mm which will be cut down but as the others have said best to buy a nose cone then worry about cutting to the correct size.
Cheers, Pewe
