eddbaz
| posted on 11/5/08 at 05:51 PM |
zx12r cooling system
My next job on the build is to plumb the zx12r engine cooling system.
I need some pipe which I think will need to be 28mm inside diameter and some 15mm inside diameter for the oil cooler and expansion tank, I need the
pipe in black and pipe that will allow for some gentle bends without kinking, I also need t-pieces that will allow a 15mm exit from a 28mm pipe,can
anyone tell me where I can get these from.
Also on the zx12r engine about an inch above the main return outlet there is a small outlet that is only a few millimeters in diameter that when the
engine is fitted in its normal use in the motorbike a small diameter pipe runs from there into the bike radiator,do I need to run this pipe in the
same way?
Cheers for any help
Ed.
eznfrank
| posted on 11/5/08 at 06:22 PM |
Hi mate, we always seem to be at the same point (I've been doing mine today). You can just use standard 28mm copper pipe from any plumbers
merchants and have it powdercoated when it's soldered. I used off cuts of the original pipework to connect it to the rad and block. If you have
an email address I can send you a map for the cooling system or see my recent thread
here which describes what goes where.
[Edited on 11/5/08 by eznfrank]
eccsmk
| posted on 11/5/08 at 08:05 PM |
i used 28mm copper too altho i got mine straight out of the back of my van
primed and painted with plasticote paint
i also used
3x28mm elbows
2x45 degree 28mm elbows
and 2 tee's
1 was 28x28x22 (for the expansion bottle
1 was 28x28x15 (for the oil cooler
eznfrank
| posted on 11/5/08 at 08:20 PM |
Yeah expensive stuff innit. I think mine was £40 for the lot at a plumbers merchants. A 3 metre length of pipe will do it no probs.
eccsmk
| posted on 11/5/08 at 08:25 PM |
erm if you say so
think mine was left over from another job
im a plumber for a living
