paulmw
posted on 10/7/08 at 09:41 AM |
Stoopid Question on Wheels
I got some new Team Dynamics (15", 195 tyres and 38 ET??)
The tyre rubs the rear arches on my Spec R. How can I check on the wheel that they have sent me the correct offset?
Cheers Paul
Mr Whippy
posted on 10/7/08 at 09:45 AM |
here you go
[Edited on 10/7/08 by Mr Whippy]
Jubal
posted on 10/7/08 at 09:58 AM |
Maybe it's because they're 7" wide. The ones you took off were 6" wide. Same offset but that means the sidewall is approx
0.5" nearer the arch.
I'll have 'em if you don't like them, 50 quid?
posted on 10/7/08 at 10:00 AM |
not a stupid question at all; that would be why are wheels round!?
speedyxjs
posted on 10/7/08 at 10:18 AM |
Why are wheels round?
whippy - i like the new avatar
TOO BADD
posted on 10/7/08 at 10:20 AM |
If you cannot change them give a bit of neg camber and ream the inside edge of the arch out with a Dremel. Worked for me.
Paul TigerB6
posted on 10/7/08 at 10:28 AM |
The offset is usually stamped into the back of one of the spokes Paul if you have a look
Kriss
posted on 10/7/08 at 01:14 PM |
shim spacer
used thes eon my clio v6 and they were fine
hubcentric ones are better for anything over 10mm i would say
eddbaz
posted on 10/7/08 at 05:06 PM |
I've just fitted a rear wheel arch to my r spec indy and I've got the exact wheels fitted team dymanics 1.2 15'' 38 offset 195
toyos and clearance seems ok.
