Author: Subject: Mikuni TB/zetec help
cliftyhanger
posted on 30/9/08 at 07:52 AM Reply With Quote
Bought a set of mikuni TB's 35mm and stamped with the number 1024 2Z2 (could be 272, but looks more like a Z). They have been respaced and fitted to a cut off zetec inlet manifold. The guy had been using the std zetec fuel rail/injectors too. The pipes to the TB injectors has been cut off.
So, can anybody identify the TBs for me, google has been no help, but that could just be me. Also anybody know what fuel pressure pump would be needed for the zetec fuel rail? I have a couple of HP pumps, but need to check their pressure is adequate. I will probably use the std fuel rail unless the TB ones would be worthwhile, but then I need to sort a fuel supply for them (or can I just use hoses?)
More questions to come as I play!
Clive
posted on 30/9/08 at 08:35 AM Reply With Quote
Any pictures? 35mm seems low for current bodies.
