Author: Subject: brake fluid sealer
posted on 12/10/08 at 10:47 PM Reply With Quote
brake fluid sealer
can anyone recommend a sealant that will is for brake systems, if there is such a thing...
MikeR
posted on 12/10/08 at 11:29 PM Reply With Quote
an extra 1/4 turn on the spanner?
or remake the pipe with a better flare on it.
(sorry i realise thats no help, but the sealants for cooling systems are a bodge, i'd be really nervous using a bodge on my brakes).
nitram38
posted on 12/10/08 at 11:42 PM Reply With Quote
No such thing.........only good mechanical engineering.
JAG
posted on 13/10/08 at 07:03 AM Reply With Quote
As already stated - no such thing.
Mainly because you don't want to risk bits of sealant floating around in the system blocking up all the very small orifices in the master cylinder and brakes.
Justin
posted on 13/10/08 at 08:57 AM Reply With Quote
maybe this!!
if it's for pipework might be worth a look (though might not work if the joint is already leaking and if you've going to take it apart to clean it you may as well rebuilt it new!!!)...
