Author: Subject: Oil cooler pipes
speedyxjs
posted on 26/10/08 at 09:01 AM Reply With Quote
Oil cooler pipes
I had to cut the pipes on my oil cooler when i stripped my donor as i couldnt undo the nuts.
Is there any way i can join the remaining parts on the cooler and the engine with anything?
Im trying to avoid buying new pipes as they are expensive, even from a breakers
If anyone has done this before pics would be handy.
ReMan
posted on 26/10/08 at 09:16 AM Reply With Quote
Something like the brass barbed hose joiner?
http://www.triple-s-tubing.com/Catalogs_FLM/FLM2005_p10.pdf
Bet you'll try harder to get them off next time!
Benzine
posted on 26/10/08 at 09:17 AM Reply With Quote
What material are the pipes you cut? Metal/rubber/braided? I had to cut some sections out of my oil cooler (as the pipes were much longer than needed) and I got some rubber oil hose from local motor factors for a couple of quid
[Edited on 26/10/08 by Benzine]
speedyxjs
posted on 26/10/08 at 10:42 AM Reply With Quote
Well i had to cut in two places. One metal and one rubber but the rubber end joins to a metal section
dhutch
posted on 26/10/08 at 02:24 PM Reply With Quote
I cant imagine theres anything special about the hose?
- You should be able to get rubber hose from a hose supplier for buttons for metres of the stuff. As long as it can stand the oil and the temp your sorted. Simple low presure hydraulic hose or simular.
Daniel
