<<  1    2  >>
New Topic New Reply
Author: Subject: AWD rolling chassis BEC
posted on 1/1/17 at 02:23 PM Reply With Quote
Originally posted by obfripper
A suzuki sj/jimny transfer box might suit this, i don't know what it's torque limit is though, but it would also give you high/low reduction gears, and various ratios are available.
Dave
Got a Jimny in the garage ATM, scrapman coming for the body tomorrow..
Problem I see for a 7 is the diffs in the axles are offset to the os and the front prop runs under the engine. That means the rear prop would be in the drivers foot well...
However there has been a few sj's done with bike engines and the transmission is well suited to using whatever you like.
posted on 1/1/17 at 02:27 PM Reply With Quote
posted on 2/1/17 at 04:48 PM Reply With Quote
And here is what the transmission looks like on the chassis. As you can see the 4x4 box is totally independent and can be used for all sorts of stuff!!
<<  1    2  >>
New Topic New Reply
