<<  1    2  >>
Author: Subject: hypothetical abs bypass...
martyn_16v
posted on 30/10/07 at 11:11 PM Reply With Quote
Originally posted by 02GF74
when power is applied, say igntion is turned on, the lamp would remain on for 1 second.
A 555 monostable generally cops a strop if the input pulse is longer than the output, so won't work as is in this application. You need to do a bit of input filtering to convert the rising edge input (ignition live coming on) into a brief pulse.
Something along these lines. of course if you're not into electron herding this is probably as difficult as actually fixing the problem, and it's naughty anyway etc etc...
<<  1    2  >>
