Author: Subject: horn push
richwill
posted on 5/1/09 at 04:45 PM Reply With Quote
horn push
Does anyone have a complete horn push from the sierra steering wheel. The one from my donor got destroyed when it was removed.
Or alternatively a boss to suit an omp steering wheel for the sierra shaft.
Cheers Rich
posted on 5/1/09 at 05:13 PM Reply With Quote
If you've retained the Sierra stalks and don't have a windscreen (wash/wipe) then you could wire the horn through the wash push on the end of the redundant stalk (using a relay). Keeps things tidy on the dash/wheel and means when/if you replace the Sierra wheel you won't have to faff around with the horn again.
Dead easy to do and SVA passable too.
COREdevelopments
posted on 5/1/09 at 06:33 PM Reply With Quote
i used a early fiesta indicator stalk which looks identicle to the sierra but has a horn push, i used this as i had it spare, as said above is a perfectly good way of doing.
Rob
