Author: Subject: Laptop shuting down
davidwag
posted on 11/1/09 at 06:38 PM Reply With Quote
Laptop shuting down
Hi all,
My girlfriends laptop keeps shutting its self down. Is there any way of checking why it does this? Not timing out, and its running on the mains. Maybe over heating, but can hear fans running and even does it if left on a table.
posted on 11/1/09 at 06:40 PM Reply With Quote
Is it XP? Looks under control panel at the events monitor. Might give some clues....
joneh
posted on 11/1/09 at 06:46 PM Reply With Quote
Probably overheating. I bet there's a nice compact dust cake inside the fan outlet...
posted on 11/1/09 at 06:57 PM Reply With Quote
Have you got a compressor in your garage? Quick blast with the blow gun would soon dislodge any crud....
eddbaz
posted on 11/1/09 at 07:19 PM Reply With Quote
I had the same problem on a laptop it was a faulty switch that shuts the laptop down when the screen and keyboard are closed together, when it was open any slight movement of the screen hinge would cause it to shutdown.
RoadkillUK
posted on 11/1/09 at 07:22 PM Reply With Quote
I vote for the overheating option, as mentioned above, try blowing it out. I do it regular with my PC's, dirty little things.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
jlparsons
posted on 11/1/09 at 07:27 PM Reply With Quote
You can check out the CPU temperature when the PC is running via various utilities you can download, do a google search and you should find some. Don't pay for one, I remember there being freeware versions. If it's not hot, then it's unlikely to be an overheating problem (though there are other things that can overheat).
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television. Keep cool; process promptly.
posted on 11/1/09 at 07:32 PM Reply With Quote
A little program called Speedfan is what I use. Very useful bit of kit.
martyn_16v
posted on 11/1/09 at 07:54 PM Reply With Quote
If it's actually powering itself off then it'll be overheating. If it's restarting itself then it will be something else, most likely a memory fault.
davidwag
posted on 11/1/09 at 10:21 PM Reply With Quote
Thanks for the replies so far. Have downloaded the Speedfan app to my laptop to have a look, so next question is, What are normal operating temps?
posted on 12/1/09 at 02:04 AM Reply With Quote
Note CPUs tend to run quite a bit hotter than desktop ones, typically between 50 and 70 degrees C depending on the CPU type, ambient temperature and how loaded it is.
If it regularly runs much over that you may have a cooling problem.
