Author: Subject: How flexible are silicon hoses
james h
posted on 27/2/09 at 05:49 PM Reply With Quote
Did a brief search before, couldn't quite see what i wanted, so...
How flexible is silicon hose when fitting over pipes? eg. will a hose of 13mm ID fit on a pipe of 15mm OD (just an example, any actual experience of such hose size differences would be appreciated (and no inuendo intended :p))
James
r1_pete
posted on 27/2/09 at 05:56 PM Reply With Quote
I have a 13mm id hose on a 15mm copper fitting, its the one teed off for the header tank in the attached, not too much force to get it on, and not unduly stretched.
Image deleted by owner
Vindi_andy
posted on 27/2/09 at 07:06 PM Reply With Quote
ive fitted 32 id onto 34 mm fittings on the motor with the swages no problem.
Wish Id done silcon throughout now got some rubber some silicon. Maybe after SVA and ive saved a few pennies up
snapper
posted on 27/2/09 at 08:39 PM Reply With Quote
Some of the cheaper silicone hoses have an inner membrane which can be pushed in if you force to hard, plus if the hose is streached to tight the hose clip can put strain on the hose and it will split at the edge of the clip
I eat to survive
I drink to forget
james h
posted on 27/2/09 at 11:19 PM Reply With Quote
Thanks for your replies, time to get my card out!
