mad-butcher
| posted on 19/3/09 at 10:41 AM |
First Real Drive
As above..
took the car out for it's first real drive yesterday Wallasey to Leyland via M53/M56/M6 85 miles each way, great fun until I went over the
Thelwall Viaduct (had to get in the inside lane, car was all over the place.)
My ears are bleeding, my arse is sore but what the hell. The one issue I wasn't happy with and it killed my back was no support for my heels ( I
keep sliding down the seat even with the belts tight ) was thinking of putting a bar across chassis in front of the pedals for some support.... any
thoughts appreciated
tony
Richard Quinn
| posted on 19/3/09 at 10:47 AM |
Bloody 'ell! What time of day were you using Thelwall? I do it twice a day, ok at busy times, but I wouldn't fancy it in a 7! Especially
when some d*ck stops in the 2nd lane to try to squeeze in to the l/h lane/slip road for either the A57, M62 Liverpool or M62 Leeds exits and wagons
have no real option but to just pull out unannounced! It's bad enough in a solid tintop!
mad-butcher
| posted on 19/3/09 at 10:57 AM |
about 10.30, and yes several balloon heads coming across the front of me at the place mentioned, bad enough being between the artics without the extra
hassle,
tony
omega0684
| posted on 19/3/09 at 11:10 AM |
haha, sounds like you had a great time, were you wearing a helmet or did you brave it and just use your sunny's? you just wait until a HGV pull
across you cuz he can't see you for toffee! (very scary)
deezee
| posted on 19/3/09 at 11:29 AM |
quote: Originally posted by mad-butcher
As above..
tony
I'm in Leasowe on Friday collecting my donor. While I'm down I could Tig weld you into the car, thus solving the sliding issue. Or cover
the seat with something sticky.
Out of curiosity, what seats do you have that are slippy?
mad-butcher
| posted on 19/3/09 at 11:38 AM |
I live in leasowe, how dare you pinch my cars, If you want a coffee call in, Ross Avenue, out of curiosity were is the car. seats are MK but there all
the same
tony
deezee
| posted on 19/3/09 at 11:43 AM |
Car is down on Birket Ave, Between Castleway and Reeds Lane. A 1.8 Sierra I found on Ebay. I've "Borrowed" a van and trailer from
work to collect it.
mad-butcher
| posted on 19/3/09 at 11:53 AM |
Good luck with the build, Neptune Car breakers is a good source for bits, but if you're into your bikes Les Jones sold his motor cycle bussiness
in duke street and bought the car breakers at the end of the block (the one with the food place on the corner.
tony
dinosaurjuice
| posted on 19/3/09 at 12:19 PM |
get some self adhesive velcro stuck to seat and trousers
rj
| posted on 19/3/09 at 01:12 PM |
I fitted a heal plate, a bit of alloy plate, bent and bolted to floor, stops be sliding down in the seat, also fitted a 6 point harness, also helps
Richard Quinn
| posted on 19/3/09 at 05:52 PM |
work to collect it.
Another from round here! We'll have to sort out a "local meeting for local people!"
Richard Quinn
| posted on 19/3/09 at 05:55 PM |
I would rather use my heels to stop me sliding than my knackers! I had a 6 point in my Autograss car. After one bad shunt where I probably
would've been hurt quite badly, I found that I was hurt quite badly - just in a different area of my body!
jacko
| posted on 19/3/09 at 07:08 PM |
As above..
tony
Hi i had a similar problem i found it helps if you tip the seat backwards
Richard Quinn
| posted on 19/3/09 at 09:08 PM |
Or face it backwards Sorry, cans are open!!
