Author: Subject: Harness Bolts
f1ngers
posted on 25/3/09 at 09:30 AM Reply With Quote
Harness Bolts
Does anyone have any 7/16" UNF Harness/Seatbelt bolts with the 'top hat' spacers or know where I can get them from?
The 'top hat' spacers are the problem as I can get bolts ok.
I have tried 2 local breakers - one has closed down and the other doesn't keep cars longer than a few days!
vinny1275
posted on 25/3/09 at 09:54 AM Reply With Quote
I've had a quick hunt round the usual suspects (rally design, demon tweeks, merlin, etc.), and can't find them - mine came with my harnesses so might be worth a call to whoever made yours.....
Happy Hunting!
Vince
blakep82
posted on 25/3/09 at 10:03 AM Reply With Quote
they don't have to be 7/16" though do they? they can be equivalent strength, so i'm sure you can use M12 cap head bolts?
[Edited on 25/3/09 by blakep82]
________________________
f1ngers
posted on 25/3/09 at 10:21 AM Reply With Quote
The bolts need to be 7/16" UNF as the nuts are already welded into the chassis (Stuart Taylor). The harnesses are Willans (bought on here) and came with eye bolts for the clip on ends at the top but no bolts/top hats for the bottom.
I looked on the Willans website and they do a Lotus Elise Fitting Kit which might do the job but there are no dimensions. I will send them an email for advice.
nib1980
posted on 25/3/09 at 10:39 AM Reply With Quote
I might be able to get some, what size top hat do you need?
M$RK_VXRD
posted on 30/3/09 at 12:39 AM Reply With Quote
i had the same problem, no bolts with my harnesses in the end i had the bolts made up at work and bought the eye bolts off the net mate
simon chapman
posted on 10/4/09 at 09:09 PM Reply With Quote
harness bolts
hi , got plenty of the bolts in various lengths ,will have to look for the tophats ,just had to buy tap for making weld in tubes for roll bar if you need some let me know
