Kosmo
posted on 27/3/09 at 10:13 PM |
Balance Bar Locking for SVA
Can someone show me what I have to pin to lock the balance bar for SVA - Photo or diagram would be great.
Kosmo
posted on 27/3/09 at 10:22 PM |
You have to make it "non adjustable". Usually means drilling and pinning.
I just covered the whole brake bias setup with a nice little box. Prevented fiddling and makes it non-adjustable. Box was rivetted in place because
they're deemed non removable ![](/images//smilies/smile.gif)
nitram38
posted on 28/3/09 at 07:49 AM |
Not true.
It can be adjustable, but not beyond the worst case senario and not while driving (so no cable adjuster).
It always has to lock the fronts before the rears.
I did my last car so that I had two half nuts on the shaft meaning I could adjust it more towards the fronts if I wanted.
At the end of the bar I had a full size nut with a roll pin.
If you have this set up, they will check the brakes at both extremes of the adjustment.
[Edited on 28/3/2009 by nitram38]
blakep82
posted on 28/3/09 at 09:59 AM |
drill and roll pin would be very difficult on my car, counld i maybe put a quick tack weld on the nut and bar instad?
or 2 nuts to lock together? nylock maybe?
________________________
nitram38
posted on 28/3/09 at 10:33 AM |
Welding the adjuster is acceptable, but lock nuts on their own are not as you can still alter the bar beyond the front bias.
A tack weld will probably be seen as easily removed so it should be a substancial weld.
