MrFozzieBear
posted on 17/4/09 at 10:24 PM |
New Donor Engine Photo Evidence?
Just been reading CKC and they’ve mentioned that VOSA now require Photo evidence if you inform them on your V5 you've changed the Donor Car
engine for another like a V8 and want to see the photo of the new engine in your donor when you come to register your locost for an age related
plate.
Doe’s anyone know a way around this?
And also what is the minimum amount of major parts needed to get an age related plate?
Thanks.
[Edited on 17/4/09 by MrFozzieBear]
Simon
posted on 18/4/09 at 12:43 AM |
It's not difficult - take engine from donor, drop in new engine, and photograph.
There's no mention of it having to work, just look convincing
Simon
ReMan
posted on 18/4/09 at 06:52 AM |
Age related = convince the inspector that you have used 2 of the lsit below
Chassis/Body
Axle
Transmission
Steering Assembly
Engine
Suspension (front and back)
and a V5 from the doner is helpful
nitram38
posted on 18/4/09 at 07:34 AM |
Chassis/Body
Axle
Transmission
Steering Assembly
Engine
The wimbledon vro gave a point for each major component and I needed 8 points.
On the donor parts alone for my F1-2 car, I could only get 6 points.
They also give 5 points for a new manufacturers chassis. I was the manufacturer so I had to give them a reciept for the new steel and that took me
over the 8 point requirement.
Just thought this might help someone in the same situation.
MrFozzieBear
posted on 18/4/09 at 11:12 AM |
yeah i wish i knew about the change last week before i stripped my donor. im kicking myself![](/images//smilies/smile.gif)
serieslandy
posted on 18/4/09 at 12:39 PM |
I'm sure someone has some pics of a donor
sierra depending on the colour that yours was.
