Valtra
posted on 11/5/09 at 12:37 AM |
brakes pull to the right
My brakes are pulling to the right . The two fronts are on one circuit the rear (live axle) are on the other .
I've re- bled the left front but it hasn't improved are there any other factors I should consider ?
"If it looks like it works and it feels like it works, then it works"
andylancaster3000
| posted on 11/5/09 at 01:41 AM |
I'll put my money on a sticky or seized caliper (probably front), particularly if they are cast iron ones.
If so, they need to be taken off and inspected for signs of damaged seals and/or corrosion between the pistons and caliper. Then either new ones or a
rebuild depending on how bad it is!
Worth noting that it'll generally pull to the side that is working more effectively.
[Edited on 11/5/09 by andylancaster3000]
clairetoo
| posted on 11/5/09 at 05:47 AM |
It'l be a sticking caliper - I had the same , and left too long (when I did get round to sorting it , I had 1 pad 1mm thick while the other was
10mm )
I had to strip , clean , and replace the piston seals to cure it - then the other side did the same
Its cuz I is blond , innit
Claire xx
Will weld for food......
| posted on 11/5/09 at 11:05 AM |
thirded - sticking piston. I had one that cuased a bit of drag - passed SVA ike that - bdidn't pull.
Had to replace seals, piston and give it a good cleaning.
Did the other side as then that was dragging more than the good side, not much but more.
Valtra
| posted on 11/5/09 at 04:08 PM |
Thanks . sounds fairly conclusive I did re furb my calipers with new seals etc but that was many years ago . sitting around in the mean time has
probably allowed a bit of corrosion in . I'll have to whip one off (left ) and check or just keep an eye out for some new ones on Ebay or in
the classifieds here ..Cheers
