Lightning
| posted on 5/3/04 at 07:49 PM |
Wind deflector
I am looking at ways of installing a wind deflector.
Any suggestions....................
I would like black to blend in with the rest of the car.
As usual cost is one of the main criteria
Kitlooney1000
| posted on 5/3/04 at 08:11 PM |
Ive just done one of those, buy a flat piece of polycabonate and diy.
Lightning
| posted on 5/3/04 at 09:45 PM |
looks good. Iwas pondering how to attach to the scuttle. Yours seems to be fiited sides and centre. Good idea
jonti
| posted on 5/3/04 at 11:08 PM |
Interesting question with regard to SVA
At what point does a "wind deflector" become a "windscreen" (and require wipers and demister etc)
Discuss:
[Edited on 5/3/04 by jonti]
OFROK
zetec
| posted on 6/3/04 at 06:33 AM |
I think when it is above about 5" or when the driver looks thru it in the normal driving position.
wicket
| posted on 6/3/04 at 12:35 PM |
Its not worth guessing at these things.
Have a look at the Seabass posting here
http://www.locostbuilders.co.uk/viewthread.php?tid=7558
with the diagram attached. Interestingly my SVA manual shows the 5 deg angle as 4 deg (June 2000 edition). There is also a table that goes with the
diagram that lists the dimensions of 'A' & 'B' varying depending on the seat back angle if it has a fixed back, as
follows:-
Angle Dim 'A' Dim 'B'
15 - 19 deg 582.5mm 178.8mm
20 - 24 deg 572.0mm 182.6mm
25 - 29 deg 562.5mm 187.2mm
30 - 34 deg 553.4mm 191.3mm
35 - 39 deg 543.5mm 194.9mm
40+ deg 534.1mm 198.8mm
This is another instance, as has been mentioned before on this forum, where a copy of the SVA manual is definitely money well spent.
[Edited on 6/3/04 by wicket]
