Nash
| posted on 13/6/09 at 10:58 PM |
BEC Question
Greetings the BEC house,
Where is the best place to find a sensibly priced bike to use as a doner for the MK power plant?
I have searched the usual places, MCN classified, Interweb breakers but not finding a bargin?!
The obvious question is what constitutes a bargin for a ZX10, ZZR 11, 12 or 14?
How much of the bike is required to convert from a x-flow?
This is all "budget research" at this moment in time but would appreciate a view from you.
Regards.....Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
mangogrooveworkshop
| posted on 13/6/09 at 11:15 PM |
look what you missed http://www.locostbuilders.co.uk/viewthread.php?tid=115242
eccsmk
| posted on 13/6/09 at 11:16 PM |
malc - yorkshire engines
he is the man!!
spdpug98
| posted on 13/6/09 at 11:27 PM |
^^^^^ As above - Malc @ Yorkshire Engines ^^^^
My Blog: http://spdpug98.wordpress.com/
ReMan
| posted on 14/6/09 at 02:56 AM |
Engine loom clocks edu carb/injectors fuel pimp are all useful as mentioned malc has an excellent reputation for quality engines else your off to the
bay
adithorp
| posted on 14/6/09 at 07:38 AM |
Malc's your man. You might find an engine cheaper on e-bay but you won't get the back-up that you will from Malc.
adrian
http://jpsc.org.uk/forum/
mark.s
| posted on 14/6/09 at 08:14 AM |
Give andy a bell aswell, he dosn't just do blades
http://www.abperformance.co.uk/
Lurch88
| posted on 14/6/09 at 08:43 AM |
BEC Engine
Still for sale
make me an offer?
http://www.locostbuilders.co.uk/viewthread.php?tid=115178
Dangle_kt
| posted on 14/6/09 at 09:16 AM |
I got my blade engine from an ebay seller, and then had to buy all the bits seperate, ecu, loom, carbs, clocks etc. etc.
It actually works out pretty expensive, so I can understand the benefit of buy a whole bike, however that doesn't get away from the problem of
having to buy the car specific bits and peices.
That is where an existing package like lurch's comes into its own, not only a tried and tested engine, but its the complete list of parts, that
you can be sure are compatible to take out the headache.
Worth checking the prop length will be ok - apart from that it seems a bloomin bargain to me.
Apart from that, you could try visordown, which has a large classified forum, or even model specific forums, eg. http://www.zx10r.co.uk/
Hope this helps
Richard Quinn
| posted on 14/6/09 at 09:29 AM |
I believe Andy gets some of his engines from Malc but due to volume/trade he is still competitive (on price, not in sidecars!)
rf900rush
| posted on 14/6/09 at 10:09 AM |
Hi
If your looking for a cheap option I still have 2 RF900R engines
Would make for a cheap install.
LINKY
The 96' one was removed from my Dax Rush to make way for my ZX12R engine.
It has had New gears and selector forks, clutch springs.
Martin
[Edited on 14/6/09 by rf900rush]
Nash
| posted on 14/6/09 at 01:44 PM |
quote: Originally posted by rf900rush
Hi
LINKY
Martin
Thanks Martin but I'm not ready to buy yet, its still research at this point.
Regards.................Neil
Nash
| posted on 14/6/09 at 01:48 PM |
quote: Originally posted by Lurch88
Still for sale
make me an offer?
Lurch, This looks like a good buy but I'm still only at the how much will it cost research bit so not in a position to move on this. Timing is
everything as they say.
Thanks for the post.
Regards...........Neil
Lurch88
| posted on 14/6/09 at 02:22 PM |
At the rate it's going you have time to save your pennies and still come back and make me an offer!
Dreaded Flea Bay next!
Lurch
[Edited on 14/6/09 by Lurch88]
