pocket rocket
posted on 4/7/09 at 02:52 PM |
can you de-cat a zetec se (sigma) ?
hi guys,
i want to make my own exhaust system for my zetec se and want a straight thru system with a motorbike can at the end.
the plan is to use something like a gsxr 1000 or 1300 can as iv been told you can get them with the cat built in, this mean i can swap it about for
MOT etc
the only problem i can see is that the engine has a pre and post cat exhaust sensor will the run ok if the post cat sensor picks up exhaust that
hasn't been through a cat?
any help or advise most welcome
Dam...iv consused my ability with my intentions!
blakep82
posted on 4/7/09 at 02:56 PM |
if you're using the original ecu then it may be a problem. in saying that, using the original ecu may be a problem anyway. the often tend to
only like being in the original car.
if you go for megasquirt, then it won't be an issue
________________________
pocket rocket
posted on 6/7/09 at 11:02 AM |
the plan is to use the standard ecu and not fit an aftermarket unit till next year.
almost everything is wired up now...apart from the exhaust
pocket rocket
posted on 7/7/09 at 06:31 PM |
anyone
