Headlamps,X/flow dizzy,coils
Clearing the garage out I have found a few bits that maybe of interest
Aldon /Flow distributor model number 103 FXY,fitted with side entry cap.
Spec below
A non-vacuum distributor, which suits most tuned X/Flow engines using camshafts such as A2, BCF1, Piper 270,285, Kent 234,244 in conjunction with side
draught carburettors. N.B. A vacuum unit must not be used when an engine is fitted with side draught carburettors.
It came off my old Westfield and has only covered 4000 miles even though it was purchased in 1994.Needs the O ring on the distributor shaft as
original was used for blanking plug when I changed to Megajolt
£60 plus carriage or you can collect if local.
2 x Lucas Sport coils one only used for approximately 500 miles the other 3500 miles
£10 each plus carriage or you can collect if local.
2 x 7 inch chrome headlamps,slightly pitted with rust one has a Lucas glass the other I cant recall right now. Photos on request
£40 for the pair plus carriage or you can collect if local.
More to come as I sort through the garage
