mookaloid
| posted on 23/7/09 at 12:55 PM |
caravan windows
A bit O/T but as there is always someone who knows the answer to everything on here......
One of my caravan windows had half an inch of water sitting in the void between the 2 layers this morning. it seems that the glue which bonds the 2
layers has failed for a short section.
I am reluctant to bung some superglue on because I suspect it will discolour the plastic. doeas anyone know the correct glue to use?
TIA
Mark
DaveFJ
| posted on 23/7/09 at 01:11 PM |
if its perspex type stuff then i would have said tensol cement
Dave
Mr Whippy
| posted on 23/7/09 at 01:25 PM |
I'd drain the water and then reseal the rubber with clear silicon bathroom sealant
Guinness
| posted on 23/7/09 at 02:01 PM |
I'd suggest the gentle application of some heat.....
Mike
roadrunner
| posted on 23/7/09 at 06:42 PM |
Is your window double glazed, if so it has failed and you need to remove it and take it to a glazing company to take apart , clean and re seal.
