Blackbird Rush
| posted on 25/7/09 at 10:09 PM |
Another BEC Lives - Video added!
After a few years of patience the megasquirted blackbird rush fired into life today
Another big step towards the road today!
One issue i have though is with the feed from the megasquirt to the fuel pump which doesn't work? i had to bridge the relay to run the pump.
Is there an easy way to check the FP output operation on the MS?
Ash.
[Edited on 25/7/09 by Blackbird Rush]
[Edited on 26/7/09 by Blackbird Rush]
omega0684
| posted on 25/7/09 at 10:18 PM |
well done ash!
mark chandler
| posted on 25/7/09 at 10:59 PM |
Congratulations
You need to look for a switched earth on pin 37 from the harness, are you sure you have not wired expecting to see a battery to fire the pump?
To test just get a dashboard light bulb, one end on +ve terminal on the battery, other end to the pump wire, you should see 5 seconds of light when
first turned on, then full on when cranking and running.
Regards Mark
[Edited on 25/7/09 by mark chandler]
Blackbird Rush
| posted on 26/7/09 at 09:46 AM |
A short vid of the rush running....
