corrado vr6
| posted on 4/8/09 at 10:50 PM |
R1 fuel pump sealer
Hi, Im using the R1 fuel pump for my build and i have got a boss for my tank from MK which i will be getting welded to my tank my question is when i
come to bolt the pump to the boss do i need to use a sealent of some sort or make a gasket if so out of what? have read about cork etc.
Any help much appriciated Greg
[Edited on 4/8/09 by corrado vr6]
http://r1indy7.wordpress.com/
spdpug98
| posted on 5/8/09 at 07:38 AM |
Hi Greg
Can't help with your question but good to see your build is moving on
I have my old clocks back so am on the road (still waiting for new ones!) so let me know when you & Dave are up the barn and i'll try and
pop up
My Blog: http://spdpug98.wordpress.com/
JekRankin
| posted on 5/8/09 at 08:33 AM |
Hi Greg,
I'm interested in this too, since I'm planning on using the same set up. Did you get a rubber o-ring with your pump, which sits inside the
aluminium ring? I always thought that this would be used to make the seal with the boss.
Jek
sickbag
| posted on 5/8/09 at 08:35 AM |
Would an original Yamaha gasket work? If so you can get one from your local Yamaha dealer or any online bike part shop.
Finally back on the job!
:{THC}:YosamiteSam
| posted on 5/8/09 at 09:45 AM |
if your looking to use a rubber type gasket you have to make sure it is made of nitril rubber - one of the only petrol proof rubbery type stuff out
there.. far better than liquid sealer - if that will suit your application
matt_gsxr
| posted on 5/8/09 at 04:47 PM |
if it is a big o-ring that you need then these guys are good.
They do any size you can imagine and deliver quickly.
Matt
link
Poorly named web-page though!
[edited to add link!!]
[Edited on 5/8/09 by matt_gsxr]
