Author: Subject: Wilwood clutch slave cylinder
omega0684
posted on 9/1/10 at 01:50 PM Reply With Quote
afternoon all;
i've been thinking about fitting a Wilwood clutch slave cylinder, seen HERE, but was just wondering; what size master cylinder would i need to fit to ?
anyone running one, pro & cons please? just thinking it might give my left leg a break from trying to to shift the cluth of my boat anchor
cheers
Alex
DIY Si
posted on 9/1/10 at 01:54 PM Reply With Quote
Could you not just change the pedal ratio you have at the moment? I don't know what the Dax pedals look like, so that may not be possible.
Otherwise, what size slave you want depends what size master you have and what you want to do. IE, a smaller bore slave will give a harder, shorter pedal, whilst a larger one will do the opposite.
Sun Tzu, The Art of War
omega0684
posted on 9/1/10 at 02:06 PM Reply With Quote
the measurements of the slave are on the link
DIY Si
posted on 9/1/10 at 04:41 PM Reply With Quote
But how does it compare to what you have now? Is it bigger or smaller?
prawnabie
posted on 9/1/10 at 05:38 PM Reply With Quote
He may be running a cable setup
DIY Si
posted on 9/1/10 at 06:09 PM Reply With Quote
Ah, you may have a point there, having read the question fully!
brianthemagical
posted on 9/1/10 at 10:46 PM Reply With Quote
It depends on the pedal ratio and travel you want in the pedal and need in the slave.
The two bore sizes are linked by a simple little equation dependant on the above.
to a certain degree anything will work, assuming the fluid volumes are acceptable.
[Edited on 9/1/10 by brianthemagical]
