dan8400
| posted on 4/2/10 at 07:40 AM |
2mm Aluminium
I bought 2mm aluminiunm (by mistake) to replace the sides on my tiger.
Got a mate who has an industrial bender so i've got it bent to fit the sides, but... i'd like to know how to cut holes in for the
suspension. Will a hole cutter do it? Or do i need something else? Got some wood hole cutterss but i doubt these will do it (plus a bit wary after
Russ's accident)
Any help/advice apreciated
Dan
boggle
| posted on 4/2/10 at 08:26 AM |
mark on where you want the holes and take them to your nearest laser cutters....
u2u me for details
907
| posted on 4/2/10 at 08:40 AM |
I find a hole punch a good tool.
Drill a hole for the bolt. Assemble the punch and die either side and tighten the bolt.
These can be used for slots i.e. 2 overlapping holes then file out the bits between.
HTH
Paul G
dan8400
| posted on 4/2/10 at 09:20 AM |
What sort of hole punch Paul? Not got lots of £££'s spare at the moment. If it's cheap enough i'll buy one
Dan
deezee
| posted on 4/2/10 at 09:39 AM |
I used a set of B&Q hole saws on my 2mm aluminium, worked fine. I've also used an air nibbler and rotary sanding wheel on a drill to great
success.
dan8400
| posted on 4/2/10 at 10:05 AM |
Do they say on them they are for cutting aluminium too? I only ask because I don't want to buy the wrong ones
Dan
dan8400
| posted on 4/2/10 at 10:13 AM |
Are there any laser cutters in lincolnshire? lol we do live in the sticks ya know
Dan
ashg
| posted on 4/2/10 at 10:51 AM |
i used a dremel
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
dan8400
| posted on 4/2/10 at 10:56 AM |
that could work ash... how about a die grinder? A friend has one i can use. Is this the same thing?
Dan
Nash
| posted on 4/2/10 at 11:27 AM |
be careful grinding Ali it will clog up Hole punch and file 2mm Ali is as soft as butter and lends itself to dressing.
I also made some "trims" to finish it off
  Front Trim On My Indy
hope that helps
....Neil
.......Neil
[Edited on 4/2/10 by Nash]
Build It, Buy It, Drive It:
Southern Kit Car Club
907
| posted on 4/2/10 at 11:41 AM |
Dan
Hi Dan
Like in the pic below. I have a 25, 35, and a 45mm
They are ace tools.
You could use a former (say 60mm) and a plate with a bigger hole (say 80mm) and pull it through a 45 hole
and end up with a 60 hole with a rolled in edge.
I could post one and then you could post it back, but you might be able to buy one for not much more than the postage.
HTH
Paul G
907
| posted on 4/2/10 at 11:58 AM |
Rolled in edge on my exhaust hole.
Paul G
James
| posted on 4/2/10 at 12:07 PM |
Just chain drill it with a 2mm drill bit and then file it smooth.
Took maybe an hour per side on my car.
James
EDIT: Type907's rolled edge looks better and no trim needed for IVA!
[Edited on 4/2/10 by James]
- Muhammad Ali
indykid
| posted on 4/2/10 at 12:27 PM |
that's beatiful paul!
can't wait for pat to get his lathe!
tom
Fred W B
| posted on 4/2/10 at 06:49 PM |
Any tool designed for wood will work on ally - Hole saw, even a spade bit.
Fred W B
Angel Acevedo
| posted on 5/2/10 at 01:48 PM |
Fred W B
If using a hole saw, use light oil to keep shavings off the cutting teeth, it will cut faster and your bit last longer.
