flak monkey
| posted on 21/2/10 at 01:24 PM |
Inline fuel pressure regulator
Due to a shortage of space in the engine bay I am on the hunt for an injection fuel pressure regulator which has inline inlet and outlet ports.
Almost all the ones I can find have the inlet and outlet at 90deg which is going to cause me problems
Thanks,
Sera
http://www.motosera.com
| posted on 21/2/10 at 01:28 PM |
Regulator can be at the back of the car, many recent cars have the pump, filter and regulator in the fuel tank.
DRC INDY 7
| posted on 21/2/10 at 01:34 PM |
Demon tweeks sell them pro flow regulator
Puddle Dodgers Club
flak monkey
My swirl pot is fed from a low pressure pump at the rear and the swirl pot is under the bonnet, along with the high pressure pump and associated
gubbins.
I also have to run a MAP line to the fuel pressure reg so it would be easier if that was under the bonnet
Sera
blakep82
| posted on 21/2/10 at 07:28 PM |
look up eds motorsport on ebay, or his own site
i got this one
http://www.edsmotorsport.co.uk/pro-flow-regulator-65-p.asp
________________________
flak monkey
| posted on 21/2/10 at 08:45 PM |
i got this one
Thanks, but thats a carbs one. I need a fuel injection one.
Sera
atomic
| posted on 24/2/10 at 05:32 PM |
If you are tight for space Fuelab 545 Series Mini Fuel Pressure Regulator's have an in-line return port or the 525 Full size also feature the
in-line return.
I've used quite a lot of Fuelab FPR's and I don't use any other in-line filters than Fuelab. They are top quality.
http://www.fuelab.com/index.php?option=com_virtuemart&page=shop.browse&category_id=2&Itemid=3
[Edited on 24/2/10 by atomic]
